928 Forum 1978-1995
Sponsored by: 928 Specialists
928 s4 hood
Old May 29, 2010 | 11:40 PM
Want to be's Avatar
Want to be
Default 928 s4 hood
Does anyone have troubles with there hood closing. My car hood is very tough to close. The hood opens with a lot of force and it takes some grunts to close the thing.
I am used to hoods never staying up unless they have a broom stick. Seriously the hood near the windshield looks a little higher than it should. I have not had a minute to view the actual problem.
Any thoughts
Old May 29, 2010 | 11:58 PM
terry gt's Avatar
terry gt
That's not right , perhaps your hinges are in need of some lube .
Old May 30, 2010 | 02:40 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
you probably have the wrong shocks open your hood to test them,
remove one and try pressing it into the floor ,
if you can do it with one hand then you have a hood shock if it takes two hands to hold the shock then you have a hatch shock .
Note the hood shock supply 35 pounds of force and the hatch shocks supply 100 pounds .
If you dont fit the correct shocks you can end up with broken ball studs or a bent hood
Old Jun 5, 2010 | 02:59 PM
Want to be's Avatar
Want to be
I oiled the hinges and it seems to be good for now. I need to compare my car to another one and see if there is a difference.
thanks guys
jpc
