Dual cooling fan question
I've searched this and found some conflicting info. Are both fans linked together and supposed to come on at the same time?
On my car, I've only ever seen the passenger side fan come on. That said, when the car is off and cool, the passenger side fan is quite free moving (i can spin the fan blades around manually). The driver's side fan moves, but I can't spin it. It's too tight. I'm assuming that this is part of the problem.
BTW - the fuses for both fans are good.
Captain Obvious
Super User
Super User
yes the both should be coming on at the same time and they both should be free spinning. Check the power at the driver side fan. If it's getting +12V, you fan is done. Also make sure that fan is not rubbing againts somethig either.
Can I simply swap the plug connections on each fan and see if the same passenger side fan comes on?
Last question... is there a way to jump the fans so I don't have to sit and wait for the car to get hot enough to trigger the fans coming on?
BTW - my A/C button doesn't work. lol. another issue for another day.
to trigger the fans, jump the temp sensor and depress the 'hood closed' swith on passenger side.
I have an extra fan motor off an 87 you can have for shipping if needed.
My little way of 'passing it forward'.
-john
Captain Obvious
Super User
Super User
It will it only get 12V when it's supposed to be running (while the other fan is running, right? (I'm just looking out for my fingers) ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Hi guys.
I'm dealing with the same problem on my '90 euro S4.
Took the wire from the working fan on passenger side and connected it to the one on the drivers side. It worked so mechanical it's OK.
So now the 1 million question is WHY doesn't the fan on the drivers side spin when AC is pressed ???? I've measured all voltages in the controlling unit in front of car nearby hood closure mechanism and posted them today in a new post.
Any thoughts ???
Thanks, Paul
Any thoughts ???
Thanks, Paul
Captain Obvious
Super User
Super User
See if the voltage disssapears when the other fsn comes on. That's what happened in my case and the problem was a pair off crappy fuseas that melted but didn't blow. Pull the fuses out and have a really good look at them and the sockets too.
Thanks, Paul
Electron Wrangler
The fans are seperately driven (each has its own driver and fuse) but should always do the same thing - either: both off, both at half speed or both at full speed...
So for a single failed fan if could be a fuse, driver, wiring or motor but given your symptoms I'd say the fan motor seems most likely...
Alan
Alan
Alan
Alan
Chronic Tool Dropper
You can test for voltage at both sides of each fuse with the fuse in place and the fan running (or supposed to be running....). A weak connection at a meted fuseholder may not show up without the load on the circiut. Test voltage to ground, should see battery voltage or very close at both ends of both fuses. A few years ago I threatened to add diagnostic ports to my spare/rebuilt output module. One of these days when I'm at home.
