Fuel Lines – 86.5
How many fuel lines should I have?
So far I have 5 removed but I am looking for a sixth.
Anyone know where the “feed” line enters the engine bay?
Thanks in advance.
P.S. I’ll post pics when done.
Thanks in advance.
As far as I recall. The feed comes in along the right fender (passengers) and connects to the damper on the left fuel rail(drivers) (install with clamps). there is a line between the fuel rails at the front (pre assembled with fittings). a line from the FPR on the rear of the right rail to the damper at the rear of the left rail. (install with clamps). and the return line from the FPR to the coler mounted at the fire wall (install with clamps).
