928 Forum 1978-1995
Sponsored by: 928 Specialists
Jack Stand Alternative?
Old 05-26-2010, 02:04 PM
KenRudd
KenRudd's Avatar
Originally Posted by rixter
ok, once again... safe jackstand placement is indicated by the arrow on the left
+1
Garage and car look familiar!
Old 05-26-2010, 05:01 PM
DonS
DonS's Avatar
Location: Live Music Capital of the World - Austin, Texas
Being a belt-and-suspenders type of guy I always try to take it a step further and use two additional jack stands (in addition to the first four) AND leave the jack at the other end just barely touching but ready to take weight. Also, two of the four have the base at a 45* angle to the car to prevent lateral tipping.
Finally, once all is in place I test the lift by (gently) pushing the car in both directions to assure myself that it's on solid footings. Some may disagree with testing but it gives you a very secure feeling about how the lift has set. If you can't move it by trying then it very probably isn't going anywhere if it's bumped. I'd still do this on any lifting mechanism.
Old 05-26-2010, 05:15 PM
checkmate1996
checkmate1996's Avatar
Originally Posted by 76FJ55
I think this set-up may make it dificult to remove the torque tube. it also seems to consume a lot of room under the car where you may want access to stuff. would be great for wheel well work and probably OK for MM/OP work. doesn't look like it will extent out to the jack points though so not sure what part of the car will be supporting the weight. one nice thing though is that with close to 50/50 weight bias it should be plenty stable.
Folks, I bought this this scissor lift about five years ago for $900. Best $900 I spent. Many of the local 928 members have seen in it action and or had their cars on the lift themselves. It works great and I wouldn't hesistate a second to buy another one. I've even removed the TT with this lift. Simply, use the lift to raise the car and then place 4 heavy duty jack stands under it or whatever else floats your boat.(I personally bought 4 3 ton 18"-44" jackstands so I can raise the car to any height. Worked great for removing the tranny). You'll have all the space you need. There isn't anything on this car that can't be done with this lift.
Old 05-26-2010, 05:25 PM
auzivision
auzivision's Avatar
I'm pretty sure a car properly set on 4 well built stands is going to be awfully hard to knock off.
I’ve tried pushing hard and giving a it few hip checks and it doesn’t budge.
Then I either take the wheels off and store them under the or leave a jack in the up position just short of carrying weight.
Old 05-26-2010, 06:40 PM
david928
david928's Avatar
If you use ramps on the front end, then the tires, though lifted vertically, are still in contact with the ground and provide lateral stability against any accidental bumping.
Old 05-26-2010, 06:57 PM
axis of evil
axis of evil's Avatar
low cost alternative
Old 05-27-2010, 04:11 PM
aaddpp
aaddpp's Avatar
Originally Posted by circlex
I'm with you on hating jack stands. I use these as shown in the pic. Not my image -- I lifted it from the web page that describes how to make them. Cost me less than $100 in wood and screws.
Mike, thanks, thats a nice looking setup looks like it gives about 19 or 20" of clearance to work. Similar to what I use, but at less weight and cost. Only draw back is that it does not allow you to tackle some of the wheels off work.
Dave
Old 05-27-2010, 07:00 PM
aaddpp
aaddpp's Avatar
Thanks all for the feedback / suggestions. Obviously a lift is the preferred option (jealous of the sweet lift Rixter !!!), but that will need to wait a while. In the meantime, my preference is obviously for something a bit a bit wider, and with fewer moving parts, but if I can't have that then Dr. Bob, your recs for some jack stands with additional supporting blocks may be put to good use.
Always appreciated,
Dave
Old 05-27-2010, 08:03 PM
Fogey1
Fogey1's Avatar
Originally Posted by danglerb
... I bought a mid rise (54" I think) for all told about $1k. Mine has 4 adjustable arms, and a riser pad on the end of the arm, so there is some amount of clearance even on the middle of the car directly over the mechanism. I wouldn't drive over it with the arms on, but off its no issue, and they come off pretty easy. ...
Awww ... it's no fun if you don't give us a link - or at least a name to Google.
Old 05-30-2010, 11:23 AM
Boganspeed
Boganspeed's Avatar
Those timber stands gave me an idea.... So we knocked these up out of some scrap at my mate's workshop.
Approx 400mmx400mm base and gives 300mm lift under the tyres.
Put some angle iron on the front stands to stop the car moving as well as the hand brake.
Super stable and has given me plenty of room to work underneath the car.
Best of all, they only cost me a bacon, egg and cheese toasted sandwich and an Iced Coffee.
Old 05-30-2010, 12:46 PM
linderpat
linderpat's Avatar
Received 2,305 Likes on 1,274 Posts
Hmm. I don't trust that design. I prefer wood for these types of lift systems.
Old 05-30-2010, 07:36 PM
Boganspeed
Boganspeed's Avatar
I'll let you know if it falls on me
Old 05-30-2010, 09:37 PM
shmark
shmark's Avatar
Jack stands are very stable when properly used. I always get the car up on them, check everything and give the car a good hip check before trusting anything. With the stands right, it won't budge. Then I put the wheels under the car for an added measure. Not living in earthquake country, I guess I don't worry as much as you left coasters. I've been thinking about one of those scissor lifts since my garage is way too low for the two-post I really want.
Quick Reply: Jack Stand Alternative?
