928 Forum 1978-1995
Sponsored by: 928 Specialists
O2 Simulator
Old 05-19-2010, 01:40 PM
Koenig-Specials 928
Koenig-Specials 928's Avatar
Default O2 Simulator
Not sure if people know that there are now O2 simulators for Off Roading or Testing. Honest, it is not for those of you eliminating your catalytic converters for an increase HP or Torque
The O2 Simulators lets you remove your catalytic converter without triggering any trouble codes. Can also be used to test if O2 sensor is bad.
Name:  O2 simulators.jpg
Actually, I dropped in to a local Corvette Meet yesterday and 2 of the cars were equipped with them. I got this info from one of them. First time I heard of the product.
Old 05-19-2010, 01:52 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,221 Likes on 1,253 Posts
Necessary on cars with post CAT O2 sensors (basically ODBII 96+).
These do not work on all cars, but a majority. Some more advanced systems are actually taking a full air / fuel measurment with the secondary O2. These work on cars looking for more of a generic signature that tells the ODBII system the CAT is functioning.
Using these on pre-CAT O2 sensors is not a good idea since the ECU needs those to adjust the mixture.
Old 05-19-2010, 05:58 PM
JHowell37
JHowell37's Avatar
I think those are just some kind of MIL (malfunction indicator light) eliminators. You won't trigger a trouble on a 928 if you remove the cat.
Old 05-20-2010, 12:11 PM
123quattro
123quattro's Avatar
Cat eliminators will only work on ECUs from about MY00 on down. All the new stuff is too smart to be fooled by them.
Old 05-20-2010, 12:36 PM
hacker-pschorr
That's not entirely true, it's not quite as easy. Those who know how usually don't go around bragging about it.
Old 05-20-2010, 12:58 PM
Koenig-Specials 928
The vettes I saw using them were ZO5s which would be like 2005 and newer (I think)
Old 05-20-2010, 02:49 PM
123quattro
123quattro's Avatar
You can bypass the secondary O2s fairly easily. Just not with $15 JC Whitney simulators that put out ~0.6 +/- .2 Vdc.
Quick Reply: O2 Simulator
