After a TON of research I ended up buying the DeVilbiss 670 Plus. They can be had for $300 new. ( retail much higher) . Its not a true HVLP but it was easy to use and clean and atomized the clear well I thought.
Devillbis great guns . Even cheap guns work well for a short period of time used to paint cars . It's all about the set up i find a 1.3 is a good all-rounder solid and base coat and clear. 15 cfm you will be losing pressure after painting one side all so you will need a 5/8 th inside diameter hose.
