Pod Bolt
Pod Bolt
I am in the process of changing out the turn signal / lights / cruise control assembly that is located just behind the steering wheel. I have used Dwaynes excellent write up / the WSM on accessing these parts of the 928, but there are three bolt torques I can't seem to find:
1. Hex bolt that holds the turn signal / lights / cruise control assembly
2. The right and left bolts (5mm Alan) that secure down the pod.
Thanks,
Dave
P.S. Anti-seize worth using?
Thanks,
Dave
For pod look just behind ign. switch and about same place on other side. For signal switch it is located on bottom and is 8mm if I recall. When lower cover is off you should see it easily. Anti-seize on what? Not necessary for pod or switch assembly.
