928 Forum 1978-1995
Sponsored by: 928 Specialists
Checking the timing
Old May 12, 2010 | 06:25 PM
jacal128's Avatar
jacal128
Default Checking the timing
I am checking the timing on my 86 928, before I hook up the 32V'r ( thanks for loaning the tool Greg, should be finished real soon. ) this looks pretty good to me. Verified #1 @ TDC, just want to see what all of you think. Thanks Jack Davis Attachment 441897
Attachment 441898
Old May 12, 2010 | 06:37 PM
76FJ55's Avatar
76FJ55
Looks like your ready to install the 32V'r. both the cam wheels line up with the cam cover marks so you are at TDC #1 compression. just make sure the crank pointer is dead on the 0 mark. if you are off at the crank you cam timing will be correspondingly out.
If you make any changes let us know how it effects the performance.
Old May 12, 2010 | 06:40 PM
Stromius's Avatar
Stromius
The scale which the 32v'r measures is beyond eye balling. Just remove the rotors and follow Ken's instructions then you'll know exactly where you are at.
Old May 12, 2010 | 07:20 PM
jacal128's Avatar
jacal128
Put the 32V'r on both sides and they are dead on 0 degrees. I guess this part went well on the TB and WP replace. Now to chase down why it is running so rich. Thanks Jack Davis
Attachment 441914 Attachment 441913
Old May 12, 2010 | 07:24 PM
jacal128's Avatar
jacal128
76FJ55, haven't had it running since I bought it and brought it home, it ran when I picked it up. Hope to have her running properly soon, she runs now but very very rich. Thanks
Old May 12, 2010 | 11:45 PM
WallyP's Avatar
WallyP
Rennlist Site Sponsor
Temp II sensor resistance?
Old May 12, 2010 | 11:52 PM
jacal128's Avatar
jacal128
The top insulator is chipped off partially, I was thinking about just replacing it. Haven't tested it yet.
Old May 13, 2010 | 12:43 AM
76FJ55's Avatar
76FJ55
Too bad we can't average our mixtures I've got an extreme lean issue with mine at the moment.
Old May 13, 2010 | 08:04 AM
jacal128's Avatar
jacal128
No doubt.
Old May 13, 2010 | 08:21 AM
jeff spahn's Avatar
jeff spahn
You can average them, through aggregate testing in the atmosphere. Doesn't help either of you though
Old May 13, 2010 | 11:20 AM
Stromius's Avatar
Stromius
Check how the wires are under the Temp2 rubber boot/plug.
Old May 13, 2010 | 12:45 PM
PorKen's Avatar
PorKen
Inventor
RE. rich running: check for gas at the FPR and damper vacuum ports. Also check that the return hose from the FPR isn't kinked/collapsed (routed improperly or replacement hose too long).
If the engine were hot, then zero/zero would be perfect. If the engine is cold, then the 1-4 side would be better off at two retard. It's a pain to adjust retard, though, so 2° may not be worth it.
The belt is running at the front of the 1-4 gear? May be a problem developing? (The belt's normal position is 2-3mm back.) IIRC, overly high tension can do this too.
Old May 21, 2010 | 12:05 AM
jacal128's Avatar
jacal128
This car apparently tracks a little to the front, don't know if its a problem developing or not. Attachment 444207
Attachment 444208
Old May 21, 2010 | 10:46 AM
blown 87's Avatar
blown 87
Rest in Peace
Jack, just saw this, glad the tool worked out for you.
Sorry I missed you when you brought it back.
Old May 21, 2010 | 11:39 PM
jacal128's Avatar
jacal128
Thanks for the use of the 32v'r. Maybe I'll be driving her soon.
