testing Temp II
Team Owner
just to be sure your testing it correctly ,....one of the test leads goes to one side of the pins and the other to ground.
Then do the other pin to ground, they should be very close to the same.
the temp sensor has two outputs , also make sure the connector wires are in good condition if you have doubts get a new connector and boot and rewire it
