928 Forum 1978-1995
Sponsored by: 928 Specialists
FS: GTS STD piston ring sets
Old May 2, 2010 | 04:10 PM
Vilhuer's Avatar
Vilhuer
Default FS: GTS STD piston ring sets
Part number 928 103 906 26 = '92-95 100mm standard size. Full engine = 8 sets for sale. GTS is only engine which uses these. Two out of three rings have different thickness than all other 100mm ring sets.
All 8 sets have been intalled into engine and run for under one minute. Two out of 8 had too wide end cap for my liking straight out of box, 0.2mm above factory limit. One set had 0.1mm over the limit gap. Instead of geting few more sets plans have changed and these are no longer needed.
New price from Porsche $150+ per set = $1200+. All 8 sets 600 euros (around $770) or best offer. All 8 can be ok in another engine. Especially in tolerance group 0 block.
Old May 2, 2010 | 04:19 PM
Shark_Week's Avatar
Shark_Week
yep , paid $1000 for my set. hope the end gaps come out ok. if you can say what was the plan changed to, to not need these any longer?
Old May 2, 2010 | 04:23 PM
Vilhuer's Avatar
Vilhuer
103mm dry steel sleeve = 5.7L.
Old May 2, 2010 | 05:57 PM
Shark_Week's Avatar
Shark_Week
sounds interesting, would love to hear more about it if you don't mind. maybe in an email or pm
Old May 3, 2010 | 11:56 AM
Vilhuer's Avatar
Vilhuer
Basically block is machined and few mm thick cast steel pipe is inserted inside cylinders and honed to size. After that its possible to coat surface with Nicasil or leave it as is. 928 Motorsport does similar setup in US.
http://www.928motorsports.com/parts/...er_sleeves.php
103mm is just max diameter I feel comfortable to use in blocks I have around. Every now and then deeply scratched blocks are available cheaply and they are perfect candidates for this. Its just that they have usual S4 and later block tower outside dimensions meaning around 116mm min diameter. (116-103)/2 = 6.5mm wall thickness which is same as rumored min thickness for Alusil. Maybe liner would allow slightly thinner remaining tower but I like to say on safe side.
Old May 3, 2010 | 02:16 PM
Shark_Week's Avatar
Shark_Week
Erkka thanks for the info. since i have tried to read every available piece of info regarding these engines i remember glossing over this info but was determined to rebuild to stock. maybe should have considered other options
