Looking for a cheap 21 mm spark plug wrench
Looking for a cheap 21 mm spark plug wrench.
My deep sockets were too thick to fit in the hole. Harbor Freight doesn’t carry a 21mm and really not much on eBay or Amazon..
Anyone, know if this will fit?
http://www.drillspot.com/products/39...EJ6_Socket?s=1
Supercharged
Kurt,
buy a cheap-o socket and take it to a bench grinder and grind it down. I do have a tool set I got from costco as an emergency set (Made by Crescent). It has a spark plug socket that fits without grinding. Set was $100 ($80 with coupon).
Chronic Tool Dropper
Kurt--
Plugs are 13/16". H-F sells a set of four plug sockets sizes in swivel-head (5/8" - 3/4" - 13/16" - 7/8") for about $10, and the 13/16" fits in the S4 covers OK. Got it to do James' car (16V) which is a little more forgiving on size, but it fits the S4 too.
For the S4, I have a H-F tool that has a permanently-attached extension on a slight swivel. It's a perfect fit in the plug holse. I haven't seen them lately at the stores through. It's perfrct becuas it never leaves the socket in the cover on removal.
Thanks for the suggestions… that should do it.
I was wondering if those ‘standard’ spark plug sockets at HF freight would be good enough. They don’t carry any metric spark plug tools.
If I had the tool in the rear compartment, I would have used it… ended up borrowing one from Brett’s car to get them out.
I wanted to have something in my tool box to use and only have fairly expensive craftsman deep sockets not worth trashing.
If this doesn’t fit… I’ll grind on it:
http://www.harborfreight.com/4-piece...set-95487.html
