928 Forum 1978-1995
Sponsored by: 928 Specialists
86.5 no tach
Old 04-28-2010, 08:56 PM
Tampa 928s
Tampa 928s's Avatar
Default 86.5 no tach
My brothers tach did not work except for just the park lamp. I purchased a used tach and none of the lamps work and the tach is still dead. I am looking at the manual and for the 86 it shows a different pin out, would the 86.5 use the 87 schematic? I am getting a signal to pin 2 verified by a scope, does anyone know what pins go to what on the tach and what I should see?
Old 04-29-2010, 09:57 AM
Tampa 928s
Tampa 928s's Avatar
This is what I have:
The signal is good square wave that changes with speed.
12v switched
The only only thing I see is Ignition buzzer to A-16 goes from ground with ignition off to open when started. I am assuming this is grounded when key is in and off to stop buzzer, although buzzer is not sounding. I am wondering if this could be the issue. This is a replacement Tach and yes I got the automatic lamps to work. The 2-Pin connector on the steering column has to be connected.
Question is bad Tach or something else, I hate to send it back and find out its another issue, comments!
With tach looking from front there is 5-posts with nuts I have the following:
Top of Tach
Top post
(12-V Ground goes to lamp on pod)
Middle of Tach
(Left-post Pin-6 12v from fuse 10) (Right post Signal Pin-2 Ctr conn with sq wave)
(Bottom-Post left Pin 16 to Ignition buzzer Bottom-Post right 12 volts to lamp on pod)
Old 04-29-2010, 10:03 AM
ptuomov
ptuomov's Avatar
I am very interested in this. Can you post a photo? Also, where in the workshop manual did you find the specs for the pin inputs?
12v switched
Top of Tach
Top post
Middle of Tach
Old 04-30-2010, 10:36 AM
Tampa 928s
Tampa 928s's Avatar
I used the schematic and traced the pins from the back of the tach. Pins are looking from the front with tach installed in pod.
Old 04-30-2010, 10:56 AM
stolarzj
stolarzj's Avatar
I just dealt with a dead tach on a 82, it ended up being one of the traces on the board was broken. Did you check if you have continuity from the all the tach nuts to the pins on connector?
Quick Reply: 86.5 no tach
