Constantine TT bearings
I have been considering these lately and saw on a posting that for general street use running two bearings was appropriate. I was hoping to here Constantine's opinion on the matter of two vs. three...
Well, it 's okay to run two (2) Super Bearings for normal street use in 928 automatics. We strongly recommend our Super Clamp too for all automatic applications.
Two (2) bearing units were used by Porsche in 928 TTs, mainly in the later 928S4 automatic models with the thicker 28mm drive shaft, although we have run across some 25mm drive shaft TTs with only two (2) also.
Porsche always used three (3) bearings units in all 928 5 speeds.
We will always recommend three (3) for all applications.
HTH,
HTH,
