928 Forum 1978-1995
Sponsored by: 928 Specialists
RDK needs reprogramming ?
Old Apr 25, 2010 | 03:38 PM
Paul Bakker's Avatar
Paul Bakker
Default RDK needs reprogramming ?
Hi.
Just bought a "new" set of design 90 rims with RDK.
I now have the standard flat disc rims with RDK.
Do I need to "reset" or do something else to make the sensors work aigain with the new rims ?
Thanks,
Paul
'90 S4 (with RDK).
Old Apr 25, 2010 | 03:46 PM
Hayk928's Avatar
Hayk928
Hi Paul,
I assume, someone's disabled your RDK? Then check first, whether pin no. 2 and 16 from the connector of the RDK-controller is bridged. Second thing would be to check the ground point no. 4 where the RDK-ECU should be connected.
Normally then it should work without additional mods.
hth,
Marc
Old Apr 25, 2010 | 03:51 PM
Paul Bakker
Originally Posted by Hayk928
Hi Paul,
hth,
Marc
Hi Marc,
no my RDK is working fine with my flat discs now. I don't have the design 90 rims yet. I'm just curious what happens when I put them under my car tommorow...
Thanks.
Old Apr 25, 2010 | 04:43 PM
Vilhuer's Avatar
Vilhuer
Should work just fine if sensors are ok. If you get error try owners manual reset method first.
Make sure tire shop do not use too high pressure if you have tires mounted to them.
Old Apr 25, 2010 | 05:48 PM
pcar928fan's Avatar
pcar928fan
Should be fine...the sensors don't care what kind of wheel is producing the field they are reading...
Old Apr 26, 2010 | 04:52 AM
Paul Bakker
Hi Paul,
hth,
Marc
Hi.
I put my tires up to 3 bar to avoid my RDK to give an error.
