Rubber bits
I found some close parts at the local hardware store. Did some measuring and marking, then with the appropriate dremmel cutting tool, made the additional groove missing from the part I found. After fussing with them (there are 3 of these things, and they need to be rubber), they fit perfectly, and the business end is the same dimension as the original nipple. I also R&R'd the washer motor - that was a bit of a little job - my one gear was frozen. Got it out, but the hole for the shaft was too tight to allow the gear to turn. Used a small drill bit and augered it out just enuff. Turns freely now.
This is the fun stuff of the car hobby. A shop could never do this kind of resto work - would be cost prohibitive. That's why many replace rather than repair these days (not shop bashing Greg - I never hesitate to let my good shop do the heavy lifting stuff on my cars
I helped pull a S4 motor this Monday, even loaned a couple of grand of tools and did not make a dime, I enjoy that part of the hobby.
One thing is for sure, it would get damned expensive to pay anybody to do that level of work.
My suggestion has always been, learn to do the work your self, or be willing to pay some one who will do it right, flat rate does not apply to a 928 in most cases.
Also, i know you are not mechanic bashing, I have read to many of your threads to ever suspect that.
)Pelican has them for $3.75 probably OEM.
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."
