928 Forum 1978-1995
Sponsored by: 928 Specialists
Relays are expensive / how often do they need to be changed?
Old 05-01-2010, 12:57 PM
Alan
Electron Wrangler
Alan's Avatar
Originally Posted by dr bob
.... But the setting mode includes operating the washer pump and spraying the glass.
What? .... No ..... something must be wrong... thats not how it works...
Alan
Old 05-01-2010, 12:59 PM
Alan
Electron Wrangler
Alan's Avatar
Originally Posted by 928 at last
Thanks Alan!
I thought the relay was for the wipers themselves.
and it's not mission critical until you get caught in a monsoon and wind up sitting on the side of the road till it passes!
No it doesn't operate the wipers in normal fixed speed modes (or tip to wipe mode) - that is all directly switched so you always have normal speed modes. The intermittent relay only controls the wiper parking and intermittent rate - so like I said not mission critical even in a rainstorm...
Alan
Old 05-01-2010, 03:06 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
Alan
Have to find the instructions to be sure. The interval is set by sequential pulls on the lever. Am I doing something wrong?
Old 05-01-2010, 03:52 PM
928 at last
928 at last's Avatar
Default Question
Rob - I'd not call Intermittent Wipers a mission critical feature (not even the parking features that it also controls) - but it is a nice convenience and cheaper and much better than the Porsche version..
https://rennlist.com/forums/showthre...eferrerid=6055
Alan
Alan,
Do you know if the VW"197" relays are interchangeable with the VW"99" relays?
Thanks,
Best,
Old 05-02-2010, 01:19 AM
928 at last
Default Alan?
Alan,
Thanks,
Best,
Just a bump.
Old 05-02-2010, 01:35 AM
Calgary Ole
Calgary Ole's Avatar
I had a signal light relay malfunction and bought one from a VW dealer that works just fine. Most of you probably already had that one figured out
Old 05-02-2010, 03:49 AM
Alan
Electron Wrangler
Alan's Avatar
Sounds like it... The rate is set only only by switching in and out of intermittent mode.
You can activate the washers as normal - but it has no effect on intermittent settings...
Alan
Old 05-02-2010, 11:00 AM
syoo8
syoo8's Avatar
Does this mean that the rheostat under the pod is completely bypassed (i.e. I don't need to replace mine?)
Quick Reply: Relays are expensive / how often do they need to be changed?
