Reverse lights only work with headlights on
Thanks Wally. And Richter, you're welcome. If you're coming to SITM 2010, I'll take you up on that beer!
I'm glad to FINALLY be able to contribute something useful!
I won't make it to SITM this year - I'm still getting the Shark roadworthy for extended trips - I have to replace the cooling lines yet, because I have a small leak from somewhere. And if I'm leaking, even though it's small, it's not holding pressure, and if it's not holding pressure, then it's not going to protect it from the Texas heat in a few months.
You nailed it though, that 2 pin connector was unplugged. The previous owner had it disconnected and wrapped in electrical tape for some reason.
