Oil cooler setup question
I'm replacing my radiator with an aftermarket unit and wanted to know if I should go with the built in oil cooler or not? My car doesn't have it in the Behr radiator now but with the SC I would like to run one. Does anyone know the metric fitting adapter sizes to run AN lines off the block to the radiator? Actually which ports on the block would be nice to know too...
It would be better if you used an external oil cooler. The radiator without any coolers will be a bunch cheaper too. You can either use the stock cooler that came on later 928's ($$$) and was positioned under the radiator, or I'm sure you could find something aftermarket that would fit.
Dan
'91 928GT S/C 475hp/460lb.ft
Dan
