928 Forum 1978-1995
Sponsored by: 928 Specialists
Disc rotors ??
Old Apr 5, 2010 | 03:17 PM
oups59's Avatar
oups59
Default Disc rotors ??
When doing my brake fluid change today, I noticed that my front rotors looks funny... like uneven wear !!
Rear are normal.
I have a set of Pagid pad installed. Thickness is at 30.9 mm (WSM = wear limits at 30 mm - 32 mm when new)
The front squeal when applying light pressure. No vibration.
Is it time to install new ones ?
File Type: jpg
File Type: jpg
Old Apr 5, 2010 | 03:45 PM
the flyin' scotsman's Avatar
the flyin' scotsman
Luc............the pics show substantial grooving............how do they feel when you rub a thumb nail over them.
I replaced the front rotors on my 88 S4..............Zimmerman cast in hole with new PBR ceramic pads.........work very well.
Old Apr 5, 2010 | 03:54 PM
AO's Avatar
AO
Supercharged
At a minimum, those should be turned if in spec. What do the pads look like? Sometimes the pad can break apart leaving an uneven surface leading to hotspots.
Edit: Oh... paint those rusty hats while you're at it.
Old Apr 5, 2010 | 04:01 PM
oups59's Avatar
oups59
Did Zimmermann make cadmium coated rotors ?
Old Apr 5, 2010 | 04:09 PM
the flyin' scotsman
I painted the zimmermans and baked them in the oven before install:
File Type: jpg
Old Apr 5, 2010 | 04:25 PM
terry gt's Avatar
terry gt
I would consider investing in new rotors and pads , maybe repainting the calipers . VHT makes nice caliper paint for yourcalipers and rotors ect. just don't let your wife know you used HER oven to dry the paint ! And especialy show pictures on this forum .
Old Apr 5, 2010 | 08:02 PM
oups59's Avatar
oups59
Originally Posted by terry gt
...just don't let your wife know you used HER oven to dry the paint ! And especialy show pictures on this forum .
Old Apr 5, 2010 | 08:03 PM
oups59's Avatar
oups59
Can it be heat related ?
