928 Forum 1978-1995
Sponsored by: 928 Specialists
fan switch and low volts
Old Apr 5, 2010 | 02:41 PM
tomshark's Avatar
tomshark
Default fan switch and low volts
i have always noticed the volt meter on occasion drop to 12 volts. and the idle will drop and sometimes the car will stall .
today while using the ac i have noticed the drop falls when i turn on and gets worse when i increase fan speed .
headlights , ac itself and all other accessories do not make such a huge drop .
the oil gauge will start to dance as soon as the volts hits 12.
battery does not die starts no problem .
what should i be looking at or is the fan such a amp draw my alternator just can not handle it ?
any ideas what i should be tackling first?
Old Apr 5, 2010 | 02:43 PM
DR's Avatar
DR
Rennlist Sponsor
Have your alternator tested. Most auto parts stores wil do a free "stress test" on the battery and alternator.
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
Old Apr 5, 2010 | 05:32 PM
tomshark's Avatar
tomshark
i ran it to the auto zone the alt was fine they said at 13.57
and the battery was also fine .
so on the way back i ran everything i could again and it stalled out in the driveway . i am wondering if my idle at 635 rpm may be to low.
so i turned the adjustment on the tb screw one rotation counter clock wise .
hopefully it will work.
Old Apr 5, 2010 | 05:44 PM
Hold On's Avatar
Hold On
Yes too low idle. Try about 750 The fans have a pretty good amp draw. If everything else checks out, look at fan relay and all connections to fan.
Old Apr 5, 2010 | 05:46 PM
tomshark's Avatar
tomshark
i als noted the biggest drain is the electric fan when that comes on wow the volt gauge drops like a rock.
Old Apr 6, 2010 | 01:21 AM
Richter12x2's Avatar
Richter12x2
What are you running for an e-fan?
