Front fender installation: What Sealant?
I will soon be in the process of reassembling the right front corner of my 85. The original fenders where installed with some sort of sealant strip (#2 and #3 in the attached PET image). Is there an alternative I can pick-up locally, or should I order some from one of the vendors?
Chronic Tool Dropper
RTV generally uses acetic acid as a curing agent, so it's not a good idea to use it for this. Plus it's a chore to adjust panels if they are glued in place. The local body shop supply/ auto paint store wil have what you need.
i just used regular seam sealer from my auto parts shop was 4 bucks a tube was easy to use just a caulking gun i was thinking more about keeping water out of the seams than squeeks
