Piece between recirc box and CE supports
There's a metal strip that fastens in under the front underside of the recirculation box. The vertical supports for the CE panel also fasten to this strip.
The strip has a right-angle edge and a ~45º angle edge. Which goes toward the front of the car? PET is little help—shows only one bend (~45º), toward the rear of the car, so I'm guessing the 90º edge goes toward the front, but I might as well be sure.
Thanks.
Thanks.
Thanks.
Thanks.
Bingo. It's at the top of the frame. See the stud and the nut nearest the top-right corner? The stud passes through a piece of bent sheetmetal, which is also visible. It looks like the square angle of the sheetmetal is toward the rear of the car. Can you confirm?
