928 Forum 1978-1995
Sponsored by: 928 Specialists
starter question
Old Mar 30, 2010 | 11:00 PM
Koenig-Specials 928's Avatar
Koenig-Specials 928
Question starter question
Every now and again when I turn the key the starter spins but does not connect to the flywheel. Whenever I retry it starts as normal. Occurs at both hot and cold. Is it because the pinion is sticking or is it an electrical issue? Car is still on blocks so removing it for a rebuild is no prob. Thanks
Old Mar 30, 2010 | 11:31 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
take the starter out and take it apart you should find some sticky oil/grease on the solenoid assembly starter drive clean this off this should return the starter to proper function
Warning dont try to clean the small gear internals just the part slides on the shaft surfaces, use some fresh wheel bearing grease on the shaft
Old Mar 30, 2010 | 11:36 PM
Shark Attack's Avatar
Shark Attack
Replace it if u are not on a tight tight budget. It's the starter
Old Mar 31, 2010 | 07:33 AM
Koenig-Specials 928
Thank you Mr. M & Kyle. I'll take her out and send out for a rebuild.
