928 Forum 1978-1995
Sponsored by: 928 Specialists
Stuck Injector
Old Mar 27, 2010 | 10:26 PM
928 at last's Avatar
928 at last
Default Stuck Injector
Any thoughts on how to fix? Been tapped..no luck.
Thanks!
Old Mar 28, 2010 | 11:27 AM
928 at last
Should add that these are reconditioned and matched...so I'm not anticipating there's a mechanical issue with the injector, and the noid light shows good signal. Connection has been checked. What voltage do these normally run at? (Can it be jumpered to check operation)?
Old Mar 28, 2010 | 11:36 AM
davek9's Avatar
davek9
You can hook up a 9v Transistor radio battery (remember those) and it should click.
May want to run some brake clean through it, what make you think it is not working?
Old Mar 28, 2010 | 11:59 AM
928 at last
Default Troubleshooting
Long story short, isolated why injector circuit #1 was going out. Stethescope indictates number 4 injector not firing which is causing the circuit to shut down under load.
Old Mar 28, 2010 | 12:12 PM
davek9's Avatar
davek9
Under load and or heat are hard faults to isolate for sure.
You could swap it to the other Injector circuit and see if the same problem follows your theory else just swap it out with another known good one.
What does that cylinders spark plug look like?
Old Mar 28, 2010 | 12:30 PM
928 at last
Default All Good
Spark is nice and strong - fresh plugs and good wires. Seems like a couple of the others were a little sticky at first but fine now. This one just won't co-operate. I'll try and coax it with the 9V battery before I take out the rail again.
Old Mar 28, 2010 | 05:22 PM
Hilton's Avatar
Hilton
I've used a 12v supply with a push button in the circuit to avoid cooking the inductive coil in the injector. Just tap the push button a few times to unstick.
Old Mar 28, 2010 | 06:41 PM
928 at last
Default 12V next.
I've used brake cleaner and multiple 9V pulses and no luck so far.....
12V is next. I'm beginning to think the coil is defective.
Old Mar 28, 2010 | 07:55 PM
Rich9928p's Avatar
Rich9928p
The fuel injectors are all wired in parallel. Battery voltage is provided when the ignition is turned on (1987 and newer) or when the fuel pump runs (1984 Euro though 1986 Euro/US). In all cases the LH provides the switch to ground (via a power transistor) with a good size capacitor there to handle the voltage spike.
Have you checked the resistance of the fuel injector? It should be in the 14 ohm range. As you might imagine, with only 14 ohms a good amount current flows with 12V across it - so don't leave it connected to a battery for any long amount of time or you can cook the coil windings. If it doesn't open, it is dead.
Old Mar 28, 2010 | 09:03 PM
Tails's Avatar
Tails
+1 to Hilton's and Rich's suggestions.
Measure resistance and if OK the try the 12 volt battery via a push button in the circuit.
Tails 1990 928S4 Auto
Old Mar 28, 2010 | 09:23 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
Ahhhh you finally found the problem. Glad to hear it.
If a 9V won't open it, then 12 probably won't either but worth a try. As a last resort, swap it out with the old one untill you get a replacement.
Old Mar 28, 2010 | 10:00 PM
928 at last
Default Hey Imre!
Yes, took some doing, and a drive up to Princess for the noid light kit, but finally was able to figure out that #4 wasn't firing.
Giving up now, it's been flushed with cleaner and pulsed with 12V with no response.
All old ones are clacking happily with the 9V, but for the sake of a couple days, I'm going to wait on the replacement and then button it up. Should be operational by the weekend. (Which would give me an excuse to criuse over to your place and be a nuisance)!
Soon,
Old Mar 28, 2010 | 10:12 PM
BIMMERMIKE's Avatar
BIMMERMIKE
Make it a Friday afternoon and I can join you and Imre....
Old Mar 28, 2010 | 10:26 PM
928 at last
Default No Promises Yet......
But this coming Friday is a definite possibility if all goes as planned.....
I'll keep you posted......pun intended.
Old Mar 29, 2010 | 01:26 AM
Imo000's Avatar
Imo000
Captain Obvious
Super User
Mine is still in storage but you guys can come over and have a look at Marc's '89 S4. I'll be working away on it, putting the TT back in.
