S4 front 4" speakers
Fitting new speakers throughout the car and I want to retain the original speaker grilles.
Anybody know how to separate the original speaker frame from the outer bezel ? - looks like it's glued in place .
Dissolve the glue ?
Cut it out ?
TIA
Dissolve the glue ?
Cut it out ?
TIA
Not the sharpest tool in the shed
Hey Jon, Sorry no help here but I am curious what speakers are you putting in? I'm at the stage on project car to begin design of the audio system. As the panels are depth limited it makes it a challenge to upgrade.
Thanks,
Dan
Thanks,
Dan
I think we're talking about separating speakers from their frames, not grills from door panel. Also early cars unscrew from door panel, later unsnap.
Anders
Yes you're right separating spkrs from the original frame - I'll thake a pic in a minute to make it clearer
Hi Dan
Sort of a cobbled together speaker system - I picked a set of Infinity reference 6510CS 6" mid/bass plus tweeters and X over for about $50US in a sale at the local auto parts shop. They didn't have any infinity 4" speakers so I took what they recommended 2 pairs of - Pioneer TS E1076. They all fit in the original spaces without additional spacers.
Rear 4" bolts straight in. Front 4" - fits fine with the pioneer grilles - I want the original grilles so some adaptaion of the originals is required.
The Infinity 6" are slightly too small (diameter) for the orignal speaker trims so some additonal brackets need to be fabricated to fix them to the OEM speaker surround.- you can do wonders with bent aluminium plate.
The infinity tweeters are in theory not required as the pioneers have a co axial tweeter . However I've glued them into the the oem tweeter frame. - Will have to play around with X overs to dtermine what works best.
Head unit will remain for now a 14 year old sony unit which had a 10CD Changer (now removed) - the phono inputs it used will connect to an ipod. Eventually when I find a head unit I like at a reasonable price that is black, has a rotary volume control, USB or SD card front input (and a cassette deck LOL) I will upgrade assuming I can find an amp for the rear that fits in the original position.
Hi Dan
Heres where I need to separate the front
![](https://rennlist.com/forums/members/jon928se-albums-928-stuff-picture5574-dsc-2748-small.jpg)
Same place on the rear of the OEM speaker showing the joint between the speaker bezel and the speaker frame
![](https://rennlist.com/forums/members/jon928se-albums-928-stuff-picture5575-dsc-2752-small.jpg)
Cheers
Cheers
Thanks Jon.
Are the infinity speakers like most current speakers, 4 ohm as opposed to the original 2 ohm? From what I've read here on several of the audio upgrade threads if you move to 4ohm speakers you need to add and external bass in order to achieve same/better sound than the original speakers.
Anders
Hi Dan
Hi Dan
Thanks Jon.
Jon did a similar thing but was able to fabricate a new bezel out of 1/8" ABS plastic sheet. I measured the ID of the original speaker grill. They snap on and have not had an issue since. I made a template out of wood then used a router table to cut the outer diamter. The inner diameter will depend on the speaker in question. The four mounting holes should line up pretty easily. I also made bezels to mount Sony 1" tweaters in place of the original, smaller speakers in my S4.
Someone stripped out the factory system from my 91 and installed a Blaupunkt Lexington CM84. They took the amp, crossovers and tweeters. They replaced the 4" speakers with a Model 4 China speaker which now need repair. Of course they messed up the factory wiring. I have not looked at what they did to the 6" ones.
Now I am in the market for almost or an entire new system. The first hurdle is find things that fit. Most of the threads here are outdated because the products seem to be now discontinued.
The MB Quart PVF 210 has been replaced with the PVI 210 which appears now to exceed the space allowed for installation.
At this point the only door and maybe rear woofer and tweeter with crossovers seems to be a MTX Audio TX4001. Anyone have experience with these ?
the 88SE (8 speaker system) had 4 ohm rear 4" speakers, rear 6.5" speakers are 4 ohm. and 4" door speakers are 4 ohm. Door tweeters also 4 ohm. I know these are all original as they have 928 part numbers on them.
Thanks Jon.
All the new speakers are 4 Ohm (as were all the original ones in my '88SE)
The difference between a 2ohm and 4 ohm speaker, simplistically speaking, just means that you need to turn up the volume more to generate the same SPL. Assuming the head unit is capable of that.
Most modern head units are designed for 4 ohm speakers hence no problem. More likely to run into problems using a modern head unit to drive 2ohm speakers as the head unit will generate too much current at too low a voltage.
