928 Forum 1978-1995
Sponsored by: 928 Specialists
Removing Speaker Cover without Breaking it???
Old 03-21-2010, 08:49 PM
Marine Blue
Marine Blue's Avatar
Default Removing Speaker Cover without Breaking it???
My drivers side Woofer speaker cover pulled right off easily and what I found is that the speaker shell had broken tabs which explains why it popped off so easily. It also explains the rattle I get at higher volumes.
My passenger side on the other hand is very difficult to remove. Does someone have a trick for removing these covers without damaging the cover or the tabs?
Any help would be appreciated.
Old 03-21-2010, 08:52 PM
pcar928fan
pcar928fan's Avatar
Don't these unscrew? I watched Bill Perry take my drivers door woofer off because it had broken screw holes so it was flopping around...I recall him just carefully and with some effort unscrewing it.
Old 03-21-2010, 08:58 PM
blitz928
blitz928's Avatar
THey should unscrew not pull off, at least mine are that way.
Old 03-21-2010, 08:59 PM
Marine Blue
So they twist off? That's how the drivers side came off but the passenger was much more difficult and I didn't want to break anything. 20 year old plastic!
I'll go give it some more effort, hopefully I won't need to replace both of them but then again they both sound lousy so maybe I should.
Thanks guys.
Old 03-21-2010, 10:41 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,434 Likes on 1,365 Posts
usually the plastic will unscrew but its also usually cross threaded so be careful you can also use these old grills if you get the same size spearkers to replace the factory units
Old 03-21-2010, 11:00 PM
Marine Blue
Well I did get them off but it required two steps. First was to twist it and the second was to use a small flathead screw driver to carefully pull them off. Luckily the second one came off without damage.
The drivers side grille needs to be replaced, it has a few small dents which I can't repair. Can't believe they cost $57.00 Ea!
Not sure what to do about the speakers. Preference would be to replace with the same but I think they're NLA. Need to make some calls this week.
Old 03-21-2010, 11:05 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
+get some some 5 min epoxy and reseal the grills to the plastic .
Try painting the grills with some Krylon semi flat for a brand new grill and plastic
Old 03-21-2010, 11:13 PM
Marine Blue
The grills are held on with the tabs right now, will the epoxy reduce the vibration caused by the woofers?
You're reading my mind regarding the paint. I was considering using the satin black trim paint for the grill but the small dents will still be present. I'm still debating if I should replace or just respray. I know I'm getting carried away but I have always felt that the small details are an important part of making the car look and feel new.
I might just sell the old one for $20 and pay the difference for the new one. Luckily the other side looks perfect.
Thank you for the suggestions!
Old 03-22-2010, 01:54 AM
Hilton
Hilton's Avatar
My '89's speaker covers clip on - no screwing at all. It has the 10 speaker factory original setup (two per door, two each side behind front seats, one each side in rear hatch area).
Each plastic cover (including the grille held on with tabs) has pairs of plastic tabs 120 degrees apart that clip into slots on the surround, and hold the cover on. There's a slight gap between each pair where you can insert a wide screwdriver (8mm head) and gently pry the tabs out. Do that for two of the 3 locations, and the cover comes off easily.
I've been looking at them for a week here on my desk while I let the quarter panels soak up Leatherique, debating whether to try gluing the plastic surrounds to repair them (4 are cracked), or just buying new ones for those locations.
Old 03-22-2010, 03:17 AM
anpo
anpo's Avatar
With the grills out, I were able to hammer out a smaller dent quite easily. Remove grills from plastic frames, use a hard flat surface and carefully tap them with the hammer from both sides. Respray and they looks like new
Old 03-22-2010, 03:49 AM
jmrjames
jmrjames's Avatar
My speakers are going or gone. I have been fearful of just prying the grills off.
I would like to see some pictures of what the grill looks like from the back. Thank you for your help.
Old 03-22-2010, 03:53 AM
Vilhuer
Vilhuer's Avatar
IIRR there are two versions of covers and later are screw version. if there are three small gaps then its clip version.
Old 03-22-2010, 06:06 AM
StratfordShark
StratfordShark's Avatar
Yes my MY88 had the screw on covers and they were always easy to remove by hand.
Now currently drive MY91 and that has the clip-on covers.
Old 03-22-2010, 07:06 AM
blitz928
blitz928's Avatar
Afshin, here's a thread from awhile back, discussing rebuilt speakers if you want to keep the car as stock as possible...
https://rennlist.com/forums/928-foru...s-rebuilt.html
Old 03-22-2010, 07:36 AM
S4ordie
Not the sharpest tool in the shed
S4ordie's Avatar
That was an "Orphaned" thread, meaning, the OP never followed up with the end result.
Quick Reply: Removing Speaker Cover without Breaking it???
