928 Forum 1978-1995
Sponsored by: 928 Specialists
Fuel Line Leak
Old 03-21-2010, 05:19 PM
ROG100
Basic Sponsor
ROG100's Avatar
Don,
See I learn something new every day. I knew it was lower but did not know it was as low as 30psi.
Why so low?
Roger
Old 03-21-2010, 08:27 PM
Don Carter
Don Carter's Avatar
Actually 30-36 I think is normal for my car. 30 was at idle. Ken explained all the variables over on the PorChip thread this morning. It's all over my head. I hear "blah, blah, blah, vacuum, blah, blah, temperatures, blah, blah..."
Old 03-21-2010, 08:33 PM
Tails
Tails's Avatar
My 2 cents worth.
The anti seize is just that, anti-seize, just as Stan has said and Bill has advised to check the sealing faces. If you follow their advise it should seal.
Telfon tape only seals when the threads of the union are the actual sealing faces.
I you do as sugggested you will reduce the friction between the thread faces and the end of the nut where if fits onto the collar of the joint piece. With the reduced friction you will obtain more force applied axially onto the actual joint faces.
Tails 1990 928S4 Auto
Old 03-21-2010, 10:06 PM
Lizard928
Lizard928's Avatar
FWIW, the fitting in question is a return line and under no real pressure.
Old 03-22-2010, 11:44 AM
aaddpp
aaddpp's Avatar
Thanks to all who helped out with the leak in the fuel line off the fuel cooler. I added some anti-seize to the threads and tightened, pressurized the system, and so far no leaks.
Quick Reply: Fuel Line Leak
