It's ALIVE!..... but maybe sick!
Close to 60 degrees today so I started up the toys. The 83 started up after a battery charge but had a lifter ticking. I let the car run for some time but the lifter never quieted down. This happened when I first got the car running after I bought it. I'm hope it quiets down again. Anyone have any experience like that?
Sounds like its cold there - what weight oil are you running? I am running 5w-40 in several cars here where temps range 10-40C or 50-105F, and NEVER get ANY lifter noise, even in the Miata which are prone to it as they age. 928 hot idle pressure ~2.5bar. Noisy lifters need LOWER weight oil, not higher to fix, at least temporarily.
jp 83 Euro S AT 52k
jp 83 Euro S AT 52k
Thanks everyone. I changed the oil before I put it up for the winter. I can't remember what weight oil but it is what is recomended for the car. It sounds like others have had this happen. I was more curious than concerned again thank you to everyone for your input.
Matt
Matt
