Amp draw of fuel pump/O2 sensor
Does anyone know of the top of their head how many amps these two would draw? I am thinking of attaching my heated wide band sensor to the O2 heater wire, that way it is only on when the car is started. My instructions say it draws 1.3 amps, do you think I will be safe on that circuit with the 15 amp fuse?
I am just going to add a new fuse for my WB system, if something goes wrong I don't want it to take out my FP ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
http://www.parts-express.com/pe/show...ource=googleps
I believe the main FP take about 10A.
I am sure you will be OK to connect the WBO2 on that circuit. That is what many SharkTuner customers use with the harness I provide for the purpose.
