Steel Ball Joint Eccentric Help
Received my new steel lower ball joint today, for my 83, but still confused where the new eccentric(928 341 466 01) goes; inner or outer hole??? And which of my original two eccentrics gets reused? I do have the Tech. Bulletin, but still am not for sure. Many thanks for any assistance, from a new 928 owner.
Supercharged
If memory serves, the eccentrics for the steel ball joint are all the same. Match up two of your old eccentrics with the new ones you got. The two left over will not be used.
Make sure you lube the eccentrics. I'd probably use antisieze. Then get it aligned when you're done.
