928 Forum 1978-1995
Sponsored by: 928 Specialists
Headlight cleaning unit doesn't work.
Old Feb 27, 2010 | 09:24 AM
Paul Bakker's Avatar
Paul Bakker
Default Headlight cleaning unit doesn't work.
Hi,
newbie here...
No washerfluid onto my headlights when I push the handle...
Windscreen washer works fine. Fluid in the resevoir.
I checked the fuse, no problem.
I don't hear any motor under the hood when I push the handle.
Any suggestions ?
If you all suggest trying a new motor-unit how difficult is it to replace it ?
Thanks!
Paul
'90 S4 (European)
Old Feb 27, 2010 | 09:31 AM
WallyP's Avatar
WallyP
Rennlist Site Sponsor
Search is your friend...
https://rennlist.com/forums/928-foru...sher-pump.html
Old Feb 27, 2010 | 09:41 AM
Leon Speed's Avatar
Leon Speed
Do you have a long list of problems
The pump is on the tank, which is located in the front right fender, so no easy access (welcome to 928 ownership ). Basically to check the pump you will have to remove the front right wheel and the plastic inside fender lining.
This thread has some pictures of the tank and pump: https://rennlist.com/forums/928-foru...mp-repair.html
Old Feb 27, 2010 | 10:18 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
if you get into the washer tank then you should also replace the fill spout and then remove the metal collar from the spout and the tank they will both rust.
A new spout is easy to remove the metal just dip the end into hot water then it slides out.
The tank will take some more doing as it will be well rusted, remove the tank from the car then throw a few handfuls of small stones into the tank with some simple green and a few cups of water and then shake the tank then rinse.
Usually the pumps can be be removed, taken apart, and cleaned, as they usually fill with rust from the removed collars
Old Feb 27, 2010 | 10:28 AM
Alan's Avatar
Alan
Electron Wrangler
Of course its designed only to work when the headlights are actually up... assume that is the case?
Alan
Old Feb 27, 2010 | 10:42 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
you can also remove the fenderwell cover and pull the lower pump connector off raise the headlights attach a test light to the wires and see if power is getting to the pump
Old Feb 27, 2010 | 04:01 PM
axis of evil's Avatar
axis of evil
when removing old calcified rubber hoses that attach to plastic fittings,(anywhere on the car) always cut the rubber off the plastic, much less pain than buying replacement bottles/fittings after you have snapped off the plastic when trying to force the hose off.
Old Feb 27, 2010 | 04:07 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
to remove the washer lines, I have found that it is easier to use a lighter to heat the ends of the hoses YMMV
