928 Forum 1978-1995
Sponsored by: 928 Specialists
New Service: Head Stud Thread Repair
Old Feb 24, 2010 | 12:17 PM
Carl Fausett's Avatar
Carl Fausett
Developer
Default New Service: Head Stud Thread Repair
We have a new service available to repair stripped-out cylinder head stud threads.
Some 928 engines are "junked" only because of a stripped head stud or head bolt. These engines can be repaired and put back into service.
Our thread repair is the correct length to fully engage all the threads in the head stud as designed. Other thread inserts shown in the photo below are too short, and apply all the load to a lesser number of engagements with the block, and that's why they fail and pull out.
Further, our thread insert uses a buttress-thread between the insert and the block, so as not to exert any outward forces upon the casting. The shape of common thread inserts is beveled, and pushes outward on the block as the stud is drawn up. This can cause cracking of the block, and failure of the insert. For this reason, our insert repair process actually strengthens the block, instead of weakening it like others do.
These have been inserted and tested and shown to hold full factory head stud torque as well or better than an undamaged stud.
A 928 bare block in a heavy cardboard box with padding will weigh about 100 pounds, and they ship via UPS ground. Turn-around time is about 1 week on this repair.
File Type: jpg
Old Feb 24, 2010 | 01:53 PM
Lizard928's Avatar
Lizard928
What are you using as an implement to install the new piece?
Old Feb 24, 2010 | 02:10 PM
Carl Fausett
Developer
We made a special tool to install the new thread insert at the bottom of the hole and at the correct height when finished.
Old Feb 24, 2010 | 02:55 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
Is this simmilar to the repair procedure to the GM Norstar(sp?) engines?
Old Feb 24, 2010 | 03:06 PM
Carl Fausett
Developer
I cant say. We did derive it from repair designed for big-block aluminum engines. So I can imagine it could be similar to that used on the Northstar.
