Murf Stage3 Kit - Question
Administrator - "Tyson"
As of February 9, 2010:
Stage-1 kit - $4995 + actual shipping cost
Stage-3 kit - $7995 + actual shipping cost
Range Master
Pepsie Lite
Pepsie Lite
And now, back to our feature presentation................
Here is the thread documenting the 86.5 we built for Shane Elliot, and his drive to Las Vegas and then Seattle after the build was complete:
https://rennlist.com/forums/928-foru...s-new-car.html
Since the end goal was a stage 3 we had limited time to play with the stage 1 setup on his car. We only ran his car at 6psi with the stage 1 kit with the following results:
Only modification to the car other than the supercharger is a Motorsports X-Pipe. Stock mufflers are still in place. Automatic transmission
Stock – 271.48rwhp
Stage 1 – 370.35rwhp (16.48hp per pound of boost @ 6psi)
Stage 3 – 473.61rwhp (18.38hp per pound of boost @ 11psi)
It should be noted he was running out fuel at the top end with the Stage 3 which can be cured with either a different fuel pressure regulator and / or an 044 pump. Because of this, the tune was kept conservative to keep him in a safe zone.
85/86 cars have a lower base fuel pressure than S4's which means even with the 42lb injectors, they are not quite enough for a Stage 3 with the stock pump / regulator. An easy upgrade is the S4 stock regulator that is a direct replacement.
Since Shane has a SharkTuner back home, he's working on these upgrades.
Stock – 271.48rwhp
Tim's ordering the parts for someone else as we speak, will be assembled once Todd has a window to assemble it.
I'm somewhere in line![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
I would PM Tim to let him know your interest, I'll be talking to him later and I'll bring it up. Might be easier / faster / cheaper? to have Todd make 2-3 all in a row. I can only speculate on that.
Just got the 86 back from paint "will post pictures later when its all together", I would like an option or at least the hope of an option. I have been looking at Meth Inj but not made up my mind yet, but for $600.00 it is looking pretty good. Any idea of the price range?
Sharkaholic
Range Master
Pepsie Lite
Pepsie Lite
Let the "rummble" begin!
Credit cards! Shiiiiiiiiiiiiiiiiiiiiiiiiiiiiit!
Tim takes credit cards now?!
Damn, THAT is gonna hurt!
You and Adam can cruise over to Green Bay, have an install party then head home. If time permits, we usually like to do a before / after on our local dyno with the SharkTuner attached.
We are working on a spring GTG and it would be fun to have an install or two that same weekend.
I'm working on some updates for the kits that will include an option to upgrade the fuel pump to an 044 right off the bat and possibly the S4 regulator for 85/86 cars too. Tim and I havne't finalized the details yet on this, just an FYI if you are doing any matinace these might be items to add to your list.
