What Parts Are These???
I have searched, but I am having trouble locating part numbers / names for two items on an '87 928.
1. The cap that covers the window washing reservoir (located just in front of the coolant res.)
2. That little rubber / plastic surround that goes around the spot you put your key in the ignition.
Thanks for your help,
Dave
Dave
While I have an 86.5 928, I did look up the part nums for the 87
The 87 has two washer reservoirs. The P/N for the cap for the reservoir in the passenger side wheel well (in front of the rad coolant reservoir) is:
928 528 181 02 (Cover)
For information, the cap for the second washer fluid reservoir is:
928 528 183 03 (Cover)
The rubber ring that goes around the ignition key P/N is:
928 347 913 00 (Rubber boot)
Roger (928RUs) has links to the PDF files on his website:
http://www.porsche.com/usa/accessori...artscatalogue/
Hopefully this is what you were looking for.
Regards,
Glenn
Regards,
Glenn
Regards,
Glenn
Regards,
Glenn
Thanks for the part numbers. I had not seen the parts catalog before - what a great resource!
Thanks,
Dave
Basic Sponsor
Washer Reservoir neck top is $13.81 and the rubber ring $2.03.
