I replaced my Brake master cyl, clutch master cyl, dread blue hose and my slave cylinder and I think I have an engagement problem. It feels like the clutch is not fully engaged. The slave cylinder I used was for a 83-86, my car is an 1980. Are the rod lengths different and can I change the rod without disconnecting the slave from the hydraulic line?
Thanks Peter
I am interested in this also, we had to shim the slave out when going to a dual disk set up which is not a good solution.
There are at least two different rod lengths for clutch-slaves. The rod for a S4 (single disc) clutch is 154mm (overall length), and the dual-disc rod is shorter-- I will pull it this afternoon and measure it.
The hard-line on the clutch slave is trapped by the starter, if you remove the clip that attaches it to the bracket on the driver's side of the oil pan then you may be able to get the slave out without disconnecting anything. (You will probably need to grab the rod with long-nose pliers and shove it back into the cylinder in order to get it out of the housing).
The hot setup is to get a new clutch hose from Greg Brown and route it around the front of the starter. That avoids the trapped-hardline problem and makes removing both starter and clutch-slave much simpler. I'll post a picture this afternoon.
Thanks guys, I re-ran all my lines, hard and soft, never had the pesky bracket. The final I had to order from Germany and it was wrong (naturally) so I bent it by hand and shortened it. I have a dual disk clutch and the rod feels like it wants to be shorter. So before I start grinding I thought I'd ask the experts!
The hot leads for the starter are nicely exposed down there! watch out!
Other project today was reinstalling my "perfect" pod. I replaced the circuit board, broke two of the connectors, fixed them (gorilla glue) and rebroke two on upon final install. Everything works, mostly, so WTF! Can't wait to drive this sucker, it's been years.
Cheers, Jim
Jim, any update on this? What I would really like to know is the measurement of the rods of an old and new slave cylinder from the end to the cylinder body when fully retracted.
Dan
'91 928GT S/C 475hp/460lb.ft
Why cant you just pull the rod out and measure it?
I can, but that won't be very useful. I am not sure if the cylinder bodies are the same and also don't know if both cylinders allow the rod to be pushed in the same distance. Maybe I'll just get an older cylinder and stick it in there.
Dan
Pretty sure the bodies push the rod out the same.
It worked on at least one, just changing the rod.
Dan
Dan, Sorry for the delay! I pulled the rod from our 88s4, which we retrofitted to a DD clutch with an old-style slave. The rod measures 138.70 mm, same number as Greg. There is no other difference that I can see between the cylinders themselves, but I did not measure that.
I went through this with my '81. What I found was the new master cylinder diameter was smaller (not by much) than the old one and it could not displace enough fluid to actuate the slave cylinder.
I had to rebuild the original master and re-install. It worked fine after that.
