Wire through firewall
Trying to run wires for a meter through the firewall. Where is the easiest place to get through. I would rather not make a new hole, just squeeze a few extra in an existing route?
Thanks.
Thanks.
Team Owner
if you look above the hood release cable it goes through a rubber grommet into the underside of the DS fender and runs next to the tempostat
Team Owner
there is also a trough grommet above the CE panel where the engine harness passes
Craic Head
Also the O2 sensor wire goes through a grommet. That's what I plan to use because that one for the harness behind the CE panel is really tight and packed (for obvious reasons).
