Clutch release problem after torque tube R&R
1 Post
I've got the Black Sea R&D rebuilt torque tube installed in the 89 GT and it seems to be working fine. Everything went back together easier than I expected but I do have a puzzling problem. Now that everything is back together, the clutch doesn't release until the very top of the pedal travel and it's not releasing completely as it slips when any amount of throttle is applied. When I install the slave cylinder, it's like the pin is too long. I can see it push the clutch arm back as I tighten the bolts on the cylinder and bring it in the final 1/2" or so. Any idea what would cause this? I seem to remember having the same issue with Woody's 5 speed S4 when we did the tb/wp and his slave cylinder had been unbolted to install the flywheel lock but I never heard what he did to fix it.
if the pin was too long this would help the problem.
However you probably got some air into the system. Also check to ensure that the pivot arm is on the ball cup bushing, and that the bushing is in good condition.
Received 1,621 Likes
+1 what Colin wrote.
There is quite a bit of "pre-tension" on the slave cylinder push rod. If all the various bits and pieces of the clutch are back where they should be and there's no air in the system, then the clutch pretty much has to work.
So, check the top of the release arm then pressure bleed the clutch system. When the clutch hydraulics are disturbed (e.g. dropping the clutch) it is not unheard of, with old components, to get air into the system.
1 Post
Your comment about the pin makes me think I didn't describe the problem correctly. Normally when the clutch pedal is pressed, it pushes the arm with the pin. What's happening is the arm is being pushed by the pin without depressing the clutch pedal so that it's like the pedal is partially depressed when it's not. Would air in the system cause this? Could air get into the system just by unbolting the slave cylinder? Nothing else in the clutch hydraulics was touched.
So your clutch system is disengaging itself?
If that is the case ensure that the pedal is returning to the top and adjust the master actuation rod to remove any preload on the system.
... so that it's like the pedal is partially depressed when it's not.
One quick check: with the slave's push rod disengaged from the release arm, wiggle the release arm. It should be pretty "loose." If it doesn't move by several MM's freely then this is a sign that it is bound-up.
Another quick check, if your cover is on and *if* your clutch friction disc isn't worn to the nubs....
Look directly and squarely into the inspection hole in the bottom of the bell housing cover. Can you see the bottom of the release arm through the hole? You shouldn't be able to see it at all if you are looking straight up through the hole.
Based upon your description, air probably isn't the problem. Something's "up" with the release arm.
1 Post
Yes, I can see the release arm through the hole. The hole for the pin is just about centered in the inspection hole. Time to drop the exhaust again and check the arm. We didn't remove the clutch but must have bumped the arm out of place while wrestling with the torque tube. I'll follow up soon with what I find.
What cfc wrote: check the arm from the top first. It'll either be a smoking gun or time for more head-scratching.
1 Post
I think maybe I had both problems. I took the cover off and checked the position of the arm. It looked right so I put the cover back on and noticed the arm is now much further back than it had been in relation to the inspection hole so I think that issue is solved just by taking it apart and putting it back together. Obviously it wasn't aligned correctly before.
Now that the arm is in the right position, I've got no clutch so I tried bleeding the slave but no luck yet. How far should the pin travel when the clutch pedal is pressed? The dinner bell is ringing so I'm going to pick up some brake fluid and try bleeding it completely tomorrow. Does the method in this thread work the best? It seems to be the simplest I've seen.
