Stop lamp issue..... Fix?
Team Owner
if one of the sensors on the MC isnt working then they should both be replaced
Shameful Thread Killer
ya thats what im guessing. im going to try to find another one, if i cant, snip snip on the light wire~! does one of the sensors on the MC tell it to turn off after you press it? if so what one, that way i can unplug it or jump it or something.
I just unpluged one mc sensor at a time to see what one worked and what one did not BUT if your going to replace one replace both they are cheap and if one has failed the other is prolly not far behind they can be bought new at most parts stores they are the same as early 80's VW rabbits
When my 'stop lamp' stayed on after replacing numerous bulbs,cleaning contacts and such, I traced the problem to a defective headlamp on/off switch. Replaced with new unit purchased from dealership and no problems since!
YES! try moving/wiggle side to side and see if stop lamp goes out . The contacts wear out, I first replaced with used one which helped then same issue. You may want to fisrt try replacing with known good unit.
Electron Wrangler
