b2 piston repair in The Tidewater (aka Hampton Roads VA)
I have a Mercedes, but as I understand it the 928 also used the Mercedes 722.3 transmission and also had B2 piston issues. I'm looking for someone to replace the B2 piston on my trans. I am capable of doing it myself, but I rather not if I can afford it. Unfortunately the MB shops won't do it saying they "don't repair transmissions, only replace them." Anybody know a shop here in The Tidewater that can do this?
There is a guy, 928fixer, that occasionally posts here, that clearly from his commentary is a skilled mechanic. Maybe send him a PM message?
I just did a B2 replacement. Interesting job. Not too bad. Parts will run you about $150. Roger has them.
In case you want to see it.
https://rennlist.com/forums/928-foru...ly-4-spd.html#
Works in reverse, but you can also, very gently, move forward, and of course once you get the trans past 2nd gear (helped to take the line off the vacuum modulator and expand out the throttle position bowden cable) it is of course fine.
I think I've read just about all the documents, it just won't be too fun doing this on my back in the cramped quarters of an apartment garage (private garage, but it's barely bigger than the car)
Have you inspected your pan yet? My reaction valve thrust pin was in my pan when I inspected it. What model MB?
Haven't gotten the pan off yet. If I'm going to pay someone to do it, I figure I'll pay them all the way, and if I'm going to do any of it myself, I'm going to do all of it myself. Price is going to determine this, so I'm waiting to get some quotes first.
BTW, one thing that might be worth mentioning - in D at idle (or slowly moving along, i.e. still in 1st gear, I don't know if it does it in the other gears or not) you can hear a light rattling noise coming from down there. Does this give any hints as to what specific aspect of the B-2 assembly went bad?
There's a Mercedes shop on the southside that says they'd do it for about $160 of labor (said he's done them before but it's been a few years). Seems worth it.
I would not have bothered for $160 labor charge. I had to do it twice before the B2 band was ultimately out of spec and I had to put in a used trans.
What exactly is the 5.2mm to 5.5mm of play this post is referring to when talking about the dog-bone?
https://rennlist.com/forums/7057066-post4.html
Ah, yeah, I know what the dogbone is but I was wondering how the play is measured. If you could send it to rrshayegan at wm dot edu I'd appreciate it. The only thing the MB manuals tell you about the trans relate to changing the fluid.
I think you are measuring the distance between the yellow arrows two times and taking the difference.
First, with the B2 piston and the brake band all the way right and the band bumped up against the dogbone, then again, after closing the band by hand.
See if that's what the manual shows.
Not shown here is a yellowish-white brake band guide, big plastic piece, that covers this area. It needs to be removed to get to the band.
