NEEDED: S4+ belt cover; GTS Balancer
928 Collector
Guys I need a centre plastic tbelt cover for S4+ and GTS harmonic balancer .. does anyone have these items?
Heinrich
Heinrich
H, I have a center cover I will give you. Will let you know when I arrive back and can make arrangements to come down.
I would like to have someone answer the question as to if the harmonic balancers are balanced to the specific engine too.
The gaskets are individual crush rings. They were run to get to stay in place when I installed them with the motor on the stand! They like to fall out just when you're ready to tighten up the manifold. I ended up using a dot of O2 sensor friendly RTV to keep them in place long enough.
Good luck!
Good luck!
