LH?
LH?
I don't even want to post this, but my red 87 5-speed runs perfectly, except occasionally it will simply die. I can immediately restart it and it runs fine. Is this potentially a sign of an upcoming LH total failure?
There are no other symptons and there is no pattern to the dying. Happens once a week or less maybe once a month... don't drive it much.
Rod
Rod
Archive Gatekeeper
You've got 3 '87's in your sig- how often does the red one die? If it's relatively frequent, why not just swap an LH out of one of the others that doesn't die? Or you could just carry a spare around until it DOES die, and then swap it out and get the dead one fixed.
No man should own just 1 928......
It's the one from Stockton.
I just thought perhaps someone had a similar experience and could lend insight.
Rod
Does it run ok otherwise? Mine was randomly dying, sometimes surging a lot. It ended up being the connector to the O2 sensor. I replaced the lame universal connector with some real crimps and it works awesome.
Rod
It's done both. No predictablility, and it does it so seldom, it's hard to see any pattern. I've yet to switch the relays, any recommendations on which to try first. I hesitate to do both at the same time, because that won't isolate the problem.
Rod
Rod
