A 1,000 mile trip and a Garmin GPS users Question
Rest in Peace
All this means is that the ETA is very well programmed. I have two Garmins. They are the best for street second best for the water (Ratheon is best on the water but $$$$). Street one is a garmin 255w.
Download the DR. Frankenstein voice. Absolutely hilarious. It randomly just says **** while you are driving.
For the Southeast the estimated speeds are to high unless you are a Kamakazi driver.
I know there are not any of these types here.
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
I think they did do a good job over all, but average estimated speeds that work in Wyoming would not work in Southern Cali or DC or Atlanta for that matter.
I know there are not any of these types here.![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
The current (ish) Garmins (I use a Nuvi 760i probably an Aus only edition) assumes you will travel precise;y at the speed limit for the routed roads to calculate the ETA. My only complaint with the unit - It puts up a target that can take you into go to jail and throw away the key territory .
Given that marine GPS ten years ago could predict your eta based on yuor current SOG you'ld think that they'ld have figured out an algorithm that would extrapolate how much in excess of the current speed limit you were travelling and recalculate based upon that ????
Rest in Peace
To have a moving average of 68.9 on a 500 mile trip that includes a couple of cites and then JUST barely beat the first ETA, you are going to spend a lot of time at a speed way past the speed limit.
I have the 760 American unit.
Administrator - "Tyson"
Once I start driving after about five minutes I always end up at the destination exactly as calculated. Meaning it must have taken into account my propensity to exceed the limit.
Mine always calculates down. Meaning if I drove the speed limit I would get there exactly on time.
I drive weekly from Guelph to Windsor. Once I get on the 401 (major highway with 100km speed limit) it will change the eta as I am driving. After about 5 minutes the ETA that it shows is within a couple of minutes of the time I actually get there. I set the cruise control to 117km/h.
From that it MUST take into account the speed I am doing and not the speed limit as other wise the 3 hour trip would be off in the neighborhood of 25 - 30 minutes. It never is.
I've used the european versions of both the the Garmin 255 and 750, and there's no chance you can make the initial time of arrival, unless your trip is mostly on highway.
Within big cities the time of arrival is so way off that it's basically a useless feature.
1979 Euro
1979 Euro
Rest in Peace
I may have exceeded the posted limit once.
Road trip to Milwaukee last Thursday I shaved 11 minutes off the initial time estimate in the rain
Blown, I think you should specify how many of those 500 miles were on hightway/interstate. I clearly said that if you go mostly highway aso you can make it.
I found it unreliable when travelling extensive distances on smaller roads. (not to mention big towns)
1979 Euro
1979 Euro
