Need help with layout of '84 euro fuse panel
Just picked up an '84 euro 5 speed and am going thru the fuses and relays, trying to figure out its electrical glitches. Problem is, I removed all the fuses before making note of what goes where!
The owners manual is for a US car and so is the info. at 928 specialists.
Would anyone have a list/description of each fuse placement? I've already found that several relays were in the wrong place from the PO.
Even a pic would be a great help
Thanks in advance
Thanks in advance
Team Owner
you can find a fuse chart at 928gt.com, go to page 2 then click on tips and links, print off a chart for the car
thks. for the reply,
I looked at that fuse chart but wasn't sure about it. Like I said in my previous post some of the relays were wrong b/c their chart was for a US.
Their fuse diagram however will be correct for a Euro?
I just want this sucker to fire right up when I get it back together.
Team Owner
IIRC there are about 2/3 fuses that are not in the US cars the chart should indicate this, dont put a fuse into a slot if it says not used, also the relays may not be exact on the part numbers you might have to do some interpolation of the info
Thks. Mrmerlin,
I spent an hour or so last night going thru. the relay portion of the panel. Many of the relays that were installed were wrong. It looks like the 928gt diagram on the fuses does show the Euro setup, so that should be ok.
I'll report back when I have it back together.
Thanks again
Thanks again
Team Owner
Ahh dont get into replacing relays that dont have the same numbers as the chart, there are quite a few on the Euro that have different PN and they work fine, best to take a picture of the relays and post it
