Replacing roof antenna
The V8 Porschephile
A bead of silicone around the perimeter of the base gasket should do the trick. Just make sure that the silicone doesn't interfere with the chassis ground of the threaded stud & nut so that reception is secured.
Finally an example where we're not being ripped off in Britain!
Convertor cable here (Halfords, looks identical to one in photo) was GBP 4.99 or about $7.90 inc sales tax.
Not trying to undercut you GAZ (I'm not going in auto parts export business), just pleased to find we're paying less for once, and from a store we nickname Halfrauds as its merchandise isn't notably keenly priced.
WOW! That's a fraction (as in less-than-half) of what I paid for the converters from the only place in the US I could find them!
Maybe there is one lonely converter hanging on an auto parts or audio store display rack somewhere, but I didn't find it.
I may try it without silicone sealant first and see if it leaks over time. I'm reluctant to put sealant on as will make future removal harder/risk paint damage as well as get squeezed outside of the base and need cleaning up before it dries.
The V8 Porschephile
Not to worry, silicone sealant will not harm the paint and once dry, removes quite easily by peeling off.
The V8 Porschephile
Randy,
A few years back, I had good success at getting a new amplifier section and a couple of different mast (regular and a short stubby) from Enfig's: http://www.enfigcarstereo.com/
It's possible that Stefan at SWStereo in S. Carolina might be helpful: www.swstereo.com
Gary--
Gary--
