928 Forum 1978-1995
Sponsored by: 928 Specialists
Car is hunting for idle, most of the time.
Old 09-10-2009, 02:31 PM
PorKen
Inventor
PorKen's Avatar
Originally Posted by RichS 1986928
The car idles very steady at about 810 RPM (according to my tach).
You can't trust the pod tach. You need an external meter, like this digital timing gun, or a fancy volt meter with frequency like Mike has, to get an accurate reading.
Old 09-10-2009, 02:47 PM
RichS 1986928
RichS 1986928's Avatar
Thanks Ken,
Mike, what kind of volt meter do you have? I've got a Fluke with a bunch of features that I've never
tried out. I've also got a Oscope, but that might be a pita.
Old 09-10-2009, 02:57 PM
Mike Frye
Craic Head
Mike Frye's Avatar
Thanks Ken,
The meter we use is Adam's. My Fluke doesn't have any of those bells and whistles either. I'll check with him or see if I can get him to chime in on this thread. I've also used my Innovate LM-1 setup (with Porken Bridgit ) with the laptop to verify it once I 'tuned' it at 2k rpms.
Old 09-11-2009, 10:58 AM
Adam Geist
Adam Geist's Avatar
Mike and I have been using my Fluke 88v for diagnostics and setting the idle. The "smoothing" feature is really nice when checking the idle and other systems. This feature smoothes out the input signals for an easier read. Highly recommend a Fluke 88v.
Adam
Old 09-11-2009, 11:10 AM
RichS 1986928
Thanks Adam, I have a Fluke 189, it says that it has Frequency capability however I've never used
it. When you check the RPM, what do you connect the leads to? Or do you need a special accessory?
Old 09-11-2009, 11:31 AM
Adam Geist
Adam Geist's Avatar
My kit came with the magnetic rpm pick-up clamp that clamps around a sparkplug wire and plugs into the 88v. Not sure if the 189 has the ability to check rpm. If so, check the Fluke website for the rpm pick-up clamp part #.
Adam
Quick Reply: Car is hunting for idle, most of the time.
