Innovate WBO2 sensor analog output question - SharkTuner II related
Supercharged
As many of you know the Innovate WBO2 sensor has 1 digital output and 2 analog outputs (analog 1 and analog 2).
I've been using analog 1 for my in-car AFR guage and analog 2 for the STer. But I've had some disparity between the two. Specifically, I'll see one value on the AFR guage (analog1), and a different value on the STer screen(analog 2).
I've checked the AFR curve through the LM programmer and they are the same.
I've also been able to correlate that the analog 2 (STer) seems to be identical to the digital output. Analog 1 (my AFR Guage) seems to be off quite a bit - like 2 ~2.5 on the lean side.
I'd like to determine if the guage is inaccurate or if there's something goofy with the analog 1 output.
Here's my question: Is there any reason why I shouldn't run both the STer and the AFR guage off the same analog output (namely analog 2)?
My initial thought is that it should be okay, but thought I'd ask the experts.
Rennlist Sponsor
Hi Andrew,
I am pretty sure that most gauges use a different "curve" than the ST. If both Analog outs are set to the same "curve" or "law" this will explain your issue.
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
![](http://www.928gt.com/images/928Specialists-COVER3-928GTcom.png)
Craic Head
While you're waiting for the experts... (EDIT: Too late, DR is in the house
Can you swap analog 1 and 2 and see if there's a difference in the logging?
That would tell you if it's the analog gauge or the output.
Supercharged
If I should be using a different curve/law for my gauge, that would be really good to know.
