How do I remove the base from the mirror?
I bought a set of aero mirrors that came from a 993 and I must change the mirror base to the 928 one but how do I remove the base from the mirror??
Regards
Niklas
Regards
Niklas
It is the procedure on how to install the aero mirrors. It should be in there.
Hope it will help you.
http://www.928intl.com/repair/gtsmir...eromirrors.pdf
take a 3/8 drive extension and put it in a vise, place the mirror base on the tip of the extension and press down ( this will push the hex looking part into its spring) then twist the base of the mirror a bit you should see the hex part unscrew into its release slots
