928 Forum 1978-1995
Sponsored by: 928 Specialists
mirror switch removal
Old Sep 3, 2009 | 01:08 AM
whiteNSXs's Avatar
whiteNSXs
Default mirror switch removal
I searched the forum before and I did not get the answer so here it is.
My mirror switch is working sporadically with slow response time with the mirrors and poor contact. I would like to remove it to clean and lube. I checked the service manual online. Apparently there is no special procedure described the removal but a picture. My car has the full leather interior which makes it very hard to pry out the switch with a flat screwdriver without putting an indentation on the leather. Is there any special trick to pop the switch?
Thanks for the help.
Steve
Old Sep 3, 2009 | 02:09 AM
jcorenman's Avatar
jcorenman
Steve
Take the armrest assembly off and push it out from underneath??
Old Sep 3, 2009 | 11:09 AM
Alan's Avatar
Alan
Electron Wrangler
Pull the mushroom cap off and grasp the stem with a pair of pliers and pull the whole thing out ... you'l be needing a new switch first though - they are not cleanable. Not very expenisive either though.
Alan
Old Sep 3, 2009 | 12:49 PM
Brian B's Avatar
Brian B
Just did that with help from Alan. New switch is about 60 bucks. Once my wiring issues got straightened out, it was a quick fix.
Old Sep 3, 2009 | 12:51 PM
Brian B's Avatar
Brian B
My switch had a threaded part that screwed into the bezel on the armrest. I just unplugged the wires and unscrewed it.
Old Sep 3, 2009 | 01:44 PM
Alan's Avatar
Alan
Electron Wrangler
Note there are 2 types of switch depending on year - I seem to recall the later oine was quite a bit cheaper... was a while ago though.
Alan
