928 Forum 1978-1995
Sponsored by: 928 Specialists
Key will not go into door lock 928 S4
Old 08-26-2009, 06:41 AM
matthewclaxton
matthewclaxton's Avatar
Default Key will not go into door lock 928 S4
Hello out there, my driver's side door lock has been giving me trouble for a week, was difficult to get the key into the lock, lots of wiggling, now it does not go in all the way even wiggling it, I can thankfully use the Passenger door to lock and open both doors. Is it the lock cylinder? where do I get a replacement? can the replacement be used with my key? and how difficult is this process?
Thank you
Old 08-26-2009, 11:32 AM
Jeff928S4
Jeff928S4's Avatar
Did ya WD-40/Graphite spray it yet?
Old 08-26-2009, 11:59 AM
Tom in Austin
Tom in Austin's Avatar
I had a problem like this, sent the lock cylinder and a key to 928 Specialists ... they got it working beautifully for something like $45 ...
Old 08-26-2009, 01:37 PM
danglerb
danglerb's Avatar
I would start with spray of some kind of penetrating cleaner, wd40 might work, but leaves a LOT of residue that attracts dirt. Maybe some contact cleaner, whatever be careful of the paint. Right after the last blast of cleaner I would blow out the remains with careful use of compressed air.
Last a graphite based lock lubricant.
R&R of the lock cylinder and rekeying a new one won't be cheap.
Old 08-26-2009, 08:41 PM
cali4sun
cali4sun's Avatar
As mentioned, I would use WD-40 or something similar (graphite/LPS) and spray it onto the actual key (both sides) and attempt to insert and remove a few times. If successful that turn lock to open and close lock a few times. After wipe off any residue on the key w/cloth. I have had luck with this.....
'89 S4 GP White/Black
'76 912E Silver/Black sunroof
Objects in mirror are losing
Old 08-26-2009, 10:28 PM
scottzj
scottzj's Avatar
Also try a light file on the key to clean off any rough edges. It might help.
Quick Reply: Key will not go into door lock 928 S4
