AEM Uego users
AEM Uego users
where are you drawing power and ground?
Mine doesn't like the stereo power and ground, need a cleaner path to battery that is still switched.
What's it doing? I've hooked up a dozen probably and never had a problem. I usually head for the cigarette lighter. Did you solder an o2 wire for some reason? That screws with the signal.
The Uego is known to be particular about its wiring. Ive had one in my last 6 cars or so. My last 928 had the same problem it reads wrong when using the radio to tap into power and ground, the 944 is just fine.
When I hook it straight to the batter power and ground to make sure thats the problem and sure enough I need a better (cleaner) connection something clean in the fuse panel.
Whats it doing? it reads wrong, reads lean. This is a common problem with Uegos to need clean power, so im wondering where other people are pulling from.
ciggy lighter is obviously right there, I will try that if I don't get a good tip in the fuse panel
